بروزآوری اخبار ChimeraTool - آخرین آپدیت‌ها و تغییرات
انتشار نسخه جدید چایمراتول 44.87.1517
Update Week – Extra Release
Since the first release of our Oppo, OnePlus and Realme Qualcomm EDL solution, we have continued testing additional models together with our users. The following devices have now been successfully verified and are fully supported.
With all updates combined, we have now reached more than 150 supported devices within the past four days.
Supported procedures:
  • Remove FRP
  • Factory Reset
  • Update Firmware
  • Restore / Store Backup
Oppo
  • Oppo A1
  • Oppo A1 Pro
  • Oppo A36
  • Oppo A53
  • Oppo A55s
  • Oppo A57T
  • Oppo A5i Pro
  • Oppo A72
  • Oppo A78
  • Oppo A83
  • Oppo A98
  • Oppo F17
  • Oppo F21 Pro
  • Oppo F23
  • Oppo F31 Pro Plus
  • Oppo Find N2
  • Oppo Find N5
  • Oppo Find X2 Lite
  • Oppo Find X2 Neo
  • Oppo K10x
  • Oppo K11X
  • Oppo R17 Pro
  • Oppo R9 Plus
  • Oppo Reno 10 Pro Plus
  • Oppo Reno 11 Pro
  • Oppo Reno 12F
  • Oppo Reno 4
  • Oppo Reno 6
  • Oppo Reno 8T
  • Oppo RX17 Pro
OnePlus
  • OnePlus Pad Pro
  • OnePlus Ace 2
Tutorial videos:
If you test additional devices, feel free to share your results together with your Work ID so we can continue expanding the supported list.
</p
ادامه مطلب...
  • Remove FRP
  • Factory Reset
  • Update Firmware
Oppo
  • Oppo A1
  • Oppo A1 Pro
  • Oppo A36
  • Oppo A53
  • Oppo A55s
  • Oppo A57T
  • Oppo A5i Pro
  • Oppo A72
  • Oppo A78
  • Oppo A83
  • Oppo A98
  • Oppo F17
  • Oppo F21 Pro
  • Oppo F23
  • Oppo F31 Pro Plus
  • Oppo Find N2
  • Oppo Find N5
  • Oppo Find X2 Lite
  • Oppo Find X2 Neo
  • Oppo K10x
  • Oppo K11X
  • Oppo R17 Pro
  • Oppo R9 Plus
  • Oppo Reno 11 Pro
  • Oppo Reno 12F
  • Oppo Reno 4
  • Oppo Reno 6
  • Oppo Reno 8T
  • Oppo RX17 Pro
OnePlus
  • OnePlus Pad Pro
  • OnePlus Ace 2
Tutorial videos:
</p
ادامه مطلب...
انتشار نسخه جدید چایمراتول 44.86.1615
Update Week – Day 3
You may have already guessed it. Our third update focuses on Realme. With this release, we are adding support for a large number of Realme Qualcomm devices that no other tool has been able to service in EDL mode before.
These models normally require authenticated programmers, which means traditional tools can only handle them through online verification. With Chimera, this limitation does not apply. You can service all supported Realme Qualcomm devices fully offline using your existing Chimera licence.
Many users have been asking for Realme Qualcomm support, and we are happy to deliver it as the next milestone of our Update Week series.
  • Remove FRP
  • Factory Reset
  • Update Firmware
Devices tested by us or our users:
  • Realme 10 Pro
  • Realme 12 Pro Plus
  • Realme 13 Pro
  • Realme 13 Pro Plus
  • Realme 14
  • Realme 14 Pro Plus
  • Realme 15
  • Realme 2 Pro
  • Realme 7i
  • Realme 9
  • Realme 9 Pro
  • Realme 9 Speed
  • Realme 9i
  • Realme C15
  • Realme C17
  • Realme C51
  • Realme GT
  • Realme GT 2
  • Realme GT 2 Pro
  • Realme GT 5
  • Realme GT 5 240W
  • Realme GT 5 Pro
  • Realme GT 6
  • Realme GT 6T
  • Realme GT 7
  • Realme GT 7 Pro
  • Realme GT 8
  • Realme GT Neo 5
  • Realme GT Neo 5 SE
  • Realme GT Neo 6
  • Realme GT Neo 6 SE
  • Realme Narzo N53
  • Realme P3
  • Realme P3 Pro
  • Realme Q5
  • Realme V25
With today’s update, we now support more than 120 successfully tested devices, and the real number is likely even higher. Many additional Realme, OnePlus and Oppo Qualcomm models should also work with this solution, even if they have not yet been verified.
Technical Notes & Tips​
  • Phone connection: Some models require you to keep the buttons pressed until the “Reconnect Battery” dialog appears to ensure a successful EDL connection.
  • OppoDL Mode: When a Qualcomm-based Oppo, OnePlus or Realme device is connected to Chimera, the system automatically starts the identification procedure. In most cases, detection completes successfully if you hold both Volume and Power buttons during the initial connection.
    Special case: OppoDL Mode Certain models may only enter a special OppoDL Mode using this method. If that happens, follow these steps to access Recovery Mode manually:
    1. Press and hold the Volume Down button while the phone is booting.
    2. Select your language once Recovery Mode appears.
    3. Tap multiple times on the “Version” indicator.
    4. When the hidden menu appears, choose Download (EDL) Mode.
    On rare models, neither button combinations nor Recovery Mode will switch the device into the proper EDL mode. In such cases, hardware Test Points are required to establish the connection.
  • AntiRollback warning: After servicing or a firmware update, the device may no longer connect in EDL mode. This can happen if the new firmware raises the AntiRollback version, making the previously compatible programmer unusable.
  • Android 15 compatibility: The solution also works after upgrading to Android 15 on Oppo 11, Oppo Open and Oppo N3.
  • OnePlus 13 note: After the first boot, the phone restarts automatically. The programmer works correctly from the second boot.
  • Tutorial videos:
You can follow all the summarized highlights of the Chimera Update Week here: https://chimeratool.com/docs/oppo-vip-update-2025
ادامه مطلب...
انتشار نسخه جدید چایمراتول 44.94.0953
Extended Oppo/OnePlus/Realme EDL Support
Our Oppo/OnePlus/Realme solution has been extended with the following models tested by us and our users:
  • OnePlus 11R
  • OnePlus 13S
  • OnePlus 13T
  • OnePlus 9
  • OnePlus Ace 6
  • OnePlus Pad 3
  • OnePlus Nord N30
  • Oppo A6 GT
  • Oppo A73
  • Oppo A76
  • Oppo A77s
  • Oppo A95
  • Oppo K10 4G
  • Oppo K11
  • Oppo K12
  • Oppo K12 Plus
  • Oppo Reno 10x Zoom
  • Oppo Reno 8Z
  • Oppo Reno 9A
  • Oppo Reno 9
  • Realme 12 4G
  • Realme 2
  • Realme GT 3
  • Realme GT Master
  • Realme GT Neo 2
  • Realme GT8 Pro
  • Realme P2 Pro
  • Realme X
On the devices above, the following procedures are now available: Remove FRP, Factory Reset, Update Firmware, Restore/Store Backup
Tutorial videos:
Mobicel Star Network Code Calculator
We have added a new feature you can use for FREE: Now you can use our Calculate Network Code tool under the Utilities to get a network unlock code for your Mobicel Star device.
Other Chimera Improvements
We made the following improvements to help the work of our users:
  • Qualcomm Flash Version Warning: If the firmware version you want to flash is higher than the version of our programmer, we'll show you a warning, because after the flash procedure, you might not be able to connect to EDL mode anymore.
  • Oppo Firmware Extraction Disk Space Check: The extraction of firmware needs a lot of space these days. We check the disk space and warn you if you don't have enough space to extract the given firmware.
  • Copyable Model Specifications: Earlier, we added the Show model specifications feature, so when you contact a phone, you will see detailed phone properties. Now you can copy the keys and values easily after selecting a specific entry.
Samsung Qualcomm Improvements
New programmers have arrived for Samsung Qualcomm.
The following models and BIT versions are supported:
  • Samsung Galaxy A02s (SM-A025U, SM-A025U1) (BIT6)
  • Samsung Galaxy A02s (SM-S124DL) (BITC)
  • Samsung Galaxy A23 5G (SM-A2360, SM-A236B, SM-A236M, SM-A236U) (BITC)
  • Samsung Galaxy A23 5G (SM-S237VL) (BITD)
  • Samsung Galaxy M23 5G (SM-S236DL) (BITE)
  • Samsung Galaxy S20 Lite 5G (SM-G7810) (BITH)
  • Samsung Galaxy S20 Lite 5G (SM-G781N) (BITD)
  • Samsung Galaxy S20 Lite 5G (SM-G781U) (BITN)
  • Samsung Galaxy S21 Plus 5G (SM-G9960) (BITE)
  • Samsung Galaxy S21 Ultra 5G (SM-G9980) (BITE)
  • Samsung Galaxy Tab A9+ WiFi (SM-X210R) (BIT4)
On the devices above, the following procedures are now available: Factory Reset, Remove FRP, Get Info, Remove FMM, Remove MDM, Repair Boot, Root, Repair Serial, CSC Change, Remove Knoxguard (*), Reset Battery Status, Remove Please Call Me Lock (**).
*: The solution works up to the February 2024 security update
**: The solution works only on Korean devices (model ID ending with the letter 'N', e.g.: SM-A235N)
ادامه مطلب...
  • OnePlus 11R
  • OnePlus 13S
  • OnePlus 13T
  • OnePlus 9
  • OnePlus Ace 6
  • OnePlus Pad 3
  • OnePlus Nord N30
  • Oppo A6 GT
  • Oppo A73
  • Oppo A76
  • Oppo A77s
  • Oppo A95
  • Oppo K10 4G
  • Oppo K11
  • Oppo K12
  • Oppo K12 Plus
  • Oppo Reno 8Z
  • Oppo Reno 9A
  • Oppo Reno 9
  • Realme 12 4G
  • Realme 2
  • Realme GT 3
  • Realme GT Master
  • Realme GT Neo 2
  • Realme GT8 Pro
  • Realme P2 Pro
  • Realme X
Tutorial videos:
ادامه مطلب...
۴۴.۹۴.۰۹۵۳ پشتیبانی گسترده EDL برای Oppo/OnePlus/Realme و بهبودهای دیگر​
پشتیبانی گسترده EDL برای Oppo/OnePlus/Realmeراه‌حل Oppo/OnePlus/Realme ما با مدل‌های زیر که توسط ما و کاربرانمان تست شده‌اند، گسترش یافته است:
  • OnePlus 11R
  • OnePlus 13S
  • OnePlus 13T
  • OnePlus 9
  • OnePlus Ace 6
  • OnePlus Pad 3
  • OnePlus Nord N30
  • Oppo A6 GT
  • Oppo A73
  • Oppo A76
  • Oppo A77s
  • Oppo A95
  • Oppo K10 4G
  • Oppo K11
  • Oppo K12
  • Oppo K12 Plus
  • Oppo Reno 8Z
  • Oppo Reno 9A
  • Oppo Reno 9
  • Realme 12 4G
  • Realme 2
  • Realme GT 3
  • Realme GT Master
  • Realme GT Neo 2
  • Realme GT8 Pro
  • Realme P2 Pro
  • Realme X
در دستگاه‌های بالا، عملیات زیر اکنون در دسترس است: حذف FRP، ریست فکتوری، به‌روزرسانی فریم‌ویر، بازیابی/ذخیره بک‌آپ
ویدیوهای آموزشی:
  • اولین در جهان: حذف FRP Oppo، OnePlus و Realme Qualcomm در حالت EDL با ChimeraTool
  • اولین در جهان: به‌روزرسانی فریم‌ویر Oppo، OnePlus و Realme Qualcomm در حالت EDL با ChimeraTool
محاسبه کد شبکه Mobicel Starما یک ویژگی جدید اضافه کرده‌ایم که می‌توانید رایگان از آن استفاده کنید: اکنون می‌توانید از ابزار Calculate Network Code در بخش Utilities برای دریافت کد آنلاک شبکه دستگاه Mobicel Star استفاده کنید.
بهبودهای دیگر Chimeraما بهبودهای زیر را برای کمک به کار کاربرانمان انجام داده‌ایم:
  • هشدار نسخه فلش Qualcomm: اگر نسخه فریم‌ویری که می‌خواهید فلش کنید بالاتر از نسخه برنامه‌نویس ما باشد، هشداری نمایش داده می‌شود، زیرا پس از عملیات فلش، ممکن است دیگر نتوانید به حالت EDL متصل شوید.
  • بررسی فضای دیسک استخراج فریم‌ویر Oppo: استخراج فریم‌ویر امروزه فضای زیادی نیاز دارد. ما فضای دیسک را چک می‌کنیم و اگر فضای کافی برای استخراج فریم‌ویر داده‌شده نداشته باشید، به شما هشدار می‌دهیم.
  • مشخصات مدل قابل کپی: قبلاً ویژگی Show model specifications را اضافه کرده بودیم، بنابراین وقتی به گوشی متصل می‌شوید، خواص دقیق گوشی را می‌بینید. اکنون می‌توانید کلیدها و مقادیر را به راحتی پس از انتخاب یک ورودی خاص کپی کنید.
بهبودهای Samsung Qualcommبرنامه‌نویس‌های جدیدی برای Samsung Qualcomm اضافه شده‌اند.مدل‌ها و نسخه‌های BIT زیر پشتیبانی می‌شوند:
در دستگاه‌های بالا، عملیات زیر اکنون در دسترس است: ریست فکتوری، حذف FRP، دریافت اطلاعات، حذف FMM، حذف MDM، تعمیر بوت، روت، تعمیر سریال، تغییر CSC، حذف Knoxguard (*)، ریست وضعیت باتری، حذف قفل Please Call Me (**).*: این راه‌حل تا به‌روزرسانی امنیتی فوریه ۲۰۲۴ کار می‌کند.**: این راه‌حل فقط روی دستگاه‌های کره‌ای کار می‌کند (مدل‌هایی که شناسه مدلشان با حرف 'N' تمام می‌شود، مثلاً: SM-A235N).
