بروزآوری اخبار ChimeraTool - آخرین آپدیت‌ها و تغییرات
انتشار نسخه جدید چایمراتول 44.07.1447
OPPO/Realme Support
We’re happy to announce broader support for OPPO/Realme devices powered by SDM665, SDM670, SDM710, SDM712, and SDM845 chipsets.
Newly Supported Models:
SDM710
  • Oppo Reno
  • Oppo Reno A
  • Oppo K3
  • Realme X
  • Oppo RX17 Pro
  • Oppo R17 Pro
  • Realme 3 Pro
  • Realme X Lite
SDM712
  • Realme 5 Pro
  • Realme XT
  • Realme Q
SDM670
  • Oppo R17 (CPH1879, PBEM00)
SDM845
  • Oppo Find X (CPH1871, PAFM00)
SD665 (Initial chipset coverage is enabled. Specific model list will be expanded in upcoming updates.)
On the devices above, the following procedures are now available: Factory Reset, Remove FRP, Get Info, Backup/Restore, Firmware Update.
Note: Availability may vary by firmware/security patch level. We’ll continue to refine performance and extend the support.
Samsung Qualcomm Improvements
New programmers have arrived for Samsung Qualcomm.
The following models and BIT versions are supported:
  • Samsung Galaxy Tab S9+ 5G (SM-X818U) (BIT6)
  • Samsung Galaxy A90 5G (SM-A9080) (BIT5)
  • Samsung Galaxy S21 Ultra 5G (SM-G9980) (BITD)
  • Samsung Galaxy Tab Active 4 Pro (SM-T638U) (BIT8)
  • Samsung Galaxy A23 5G (SM-A236M) (BITB)
  • Samsung Galaxy A23 5G (SM-A236B) (BITB)
  • Samsung Galaxy Tab S7 FE (SM-T733) (BIT9)
  • Samsung Galaxy S23 5G (SC-51D) (BIT1)
  • Samsung Galaxy S24 (SC-51E) (BIT1)
  • Samsung Galaxy S20 5G (SM-G981U) (BITD)
  • Samsung Galaxy S20 5G (SM-G981V) (BITD)
  • Samsung Galaxy S20+ 5G (SM-G986U) (BITD)
  • Samsung Galaxy S20 Ultra 5G (SM-G988U) (BITD)
  • Samsung Galaxy Note 20 5G (SM-N981U) (BITD)
  • Samsung Galaxy Note 20 Ultra 5G (SM-N986U) (BITD)
  • Samsung Galaxy Tab A9+ 5G (SM-X216R) (BIT1)
On the devices above, the following procedures are now available: Factory Reset, Remove FRP, Get Info, Remove FMM, Remove MDM, Repair Boot, Root, Repair Serial, CSC Change, Remove Knoxguard (*), Reset Battery Status.
*: The solution works up to the February 2024 security update
ادامه مطلب...
انتشار نسخه جدید چایمراتول 44.09.1253
OPPO/Realme Support
SDM710
  • Oppo Reno
  • Oppo Reno A
  • Oppo K3
  • Realme X
  • Oppo RX17 Pro
  • Oppo R17 Pro
  • Realme 3 Pro
  • Realme X Lite
SDM712
  • Realme 5 Pro
  • Realme XT
  • Realme Q
SDM670
SDM845
ادامه مطلب...
OPPO/Realme Support
SDM710
  • Oppo Reno
  • Oppo Reno A
  • Oppo K3
  • Realme X
  • Oppo RX17 Pro
  • Oppo R17 Pro
  • Realme 3 Pro
  • Realme X Lite
SDM712
  • Realme 5 Pro
  • Realme XT
  • Realme Q
SDM670
SDM845
ادامه مطلب...
OPPO/Realme Support
SDM710
  • Oppo Reno
  • Oppo Reno A
  • Oppo K3
  • Realme X
  • Oppo RX17 Pro
  • Oppo R17 Pro
  • Realme 3 Pro
  • Realme X Lite
SDM712
  • Realme 5 Pro
  • Realme XT
  • Realme Q
SDM670
SDM845
ادامه مطلب...
OPPO/Realme Support
SDM710
  • Oppo Reno
  • Oppo Reno A
  • Oppo K3
  • Realme X
  • Oppo RX17 Pro
  • Oppo R17 Pro
  • Realme 3 Pro
  • Realme X Lite
SDM712
  • Realme 5 Pro
  • Realme XT
  • Realme Q
SDM670
SDM845
ادامه مطلب...
انتشار نسخه جدید چایمراتول 43.32.1437
Samsung New Security Update
We've updated support for the latest security patches as well as Android 15 across a wide range of Samsung models.
The following ADB-based procedures have been improved and extended:
  • Change CSC via ADB
  • Read Codes via ADB
  • Network Factory Reset via ADB
  • KnoxGuard Bypass via ADB
Enjoy broader compatibility and smoother operations with the latest firmwares!
MTK Oppo Remove FRP Fix
We've fixed the FRP Remove procedure for MTK-based Oppo devices.
This update ensures that when the procedure completes successfully, FRP is actually removed on all related devices — giving you more reliable and predictable results.
Extended MTK Support
We have added a new Samsung MTK model to be used in the Device Wizard tab:
  • Samsung Galaxy A25 5G (SC-53F)
Please have a look at our short video tutorials to learn how to use our new Device Wizard function with MTK devices:
We hope these tutorials help you get started quickly and easily!
  • Samsung Galaxy A23 (SM-A235F) (BITA)
  • Samsung Galaxy A23 (SM-A235N) (BIT9)
  • Samsung Galaxy A52s 5G (SM-A528N) (BIT7)
  • Samsung Galaxy M23 5G (SM-M236L) (BIT9)
  • Samsung Galaxy M52 5G (SM-M526B) (BIT7)
  • Samsung Galaxy M52 5G (SM-M526BR) (BIT7)
  • Samsung Galaxy Note 20 5G (SM-N9860) (BITD)
  • Samsung Galaxy S20 Lite 5G (SM-G781W) (BITJ)
  • Samsung Galaxy S21 FE 5G (SM-G990B2) (BITC)
  • Samsung Galaxy S22 5G (SM-S901N) (BIT7)
  • Samsung Galaxy S22 Ultra 5G (SM-S9080) (BIT9)
  • Samsung Galaxy Z Flip 4 5G (SM-F721B) (BITA)
  • Samsung Galaxy Z Flip 5 5G (SM-F7310) (BIT7)
  • Samsung Galaxy Z Fold 4 5G (SM-F936B) (BITA)
On the devices above, the following procedures are now available: Factory Reset, Remove FRP, Get Info, Remove FMM, Remove MDM, Repair Boot, Root, Repair Serial, CSC Change, Remove Knoxguard (*), Reset Battery Status, Remove Please Call Me Lock (**).
**: The solution works only on Korean devices (model ID ending with the letter 'N', e.g.: SM-A235N)
ادامه مطلب...
انتشار نسخه جدید چایمراتول 44.16.1335
  • Samsung Galaxy A05s (SM-A057M) (BITA)
  • Samsung Galaxy Note 20 5G (SM-N981N) (BITA)
  • Samsung Galaxy Note 20 5G (SM-N981W, SM-N9860) (BITE)
  • Samsung Galaxy Note 20 Ultra 5G (SM-N986N) (BITA)
  • Samsung Galaxy Note 20 Ultra 5G (SM-N986W) (BITE)
  • Samsung Galaxy S21 FE 5G (SM-G9900) (BITF)
  • Samsung Galaxy S21 FE 5G (SM-G990B2) (BITE)
  • Samsung Galaxy S21 FE 5G (SM-G990U2) (BITG)
  • Samsung Galaxy Tab A9+ 5G (SM-X218U) (BIT8)
  • Samsung Galaxy Z Flip 3 5G (SM-F711N) (BITB)
  • Samsung Galaxy Z Flip 3 5G (SM-F711B) (BITF)
  • Samsung Galaxy Z Flip 3 5G (SM-F7110, SM-F711U) (BITE)
  • Samsung Galaxy Z Fold 3 5G (SM-F926N) (BITA)
  • Samsung Galaxy Z Fold 3 5G (SM-F9260, SM-F926U) (BITD)
  • Samsung Galaxy Z Fold 3 5G (SM-F926B) (BITE)
ادامه مطلب...
ادامه مطلب...
ادامه مطلب...
انتشار نسخه جدید چایمراتول 44.21.1017
ادامه مطلب...
ادامه مطلب...
ادامه مطلب...
ادامه مطلب...
ادامه مطلب...
ادامه مطلب...
ادامه مطلب...
ادامه مطلب...
OPPO/Realme Support
SDM710
  • Oppo Reno
  • Oppo Reno A
  • Oppo K3
  • Realme X
  • Oppo RX17 Pro
  • Oppo R17 Pro
  • Realme 3 Pro
  • Realme X Lite
SDM712
  • Realme 5 Pro
  • Realme XT
  • Realme Q
SDM670
SDM845
ادامه مطلب...
